weird miss, stumble at load/low rpms...
my 94 Z runs fine cold, when good and warm, only around 2500 or so rpms it feels like it's losing spark, if you put more gas to it then it runs fine, but when you're cruising with it it does this?
mainly when the cruise is on i notice it, but i think that's because it's at a constant rpm/speed.
if you're shifting often and never at the same rpm long you never even notice it, but it started a couple of weeks ago.
i put a new TPS on there that i had from my last car and still no change, personally it feels like an OPTI or an ignition module, i have an extra module, and i'll probably swap it out tonight after work.
any help is much appreciated.
where is a good place to buy an opti if the need were to arise?
ihad the same problem at low rpms when i punched it it would run fine turned out i had small head gasket leak the way to check this look at the coolant reserve dip stick mine had a grey clay like substance(carbon)all over it .I retorqed problem went away
tommalcolm
Sep 11, 2015 03:39 PM
