Effective Valve Mass, Effective Lifter Mass
Old Jan 15, 2007 | 09:56 PM
1LESSZ28's Avatar
Stock lifters. Comp 918 Valve Springs, steel retainers, LT4 Roller Rockers, Stock Heads,
(weight of) Retainer + locks
(weight of) spring + damper
(weight of) valve weight
(weight of) rocker arm w/o fulcrum
the above I need to calcualte effective valve mass.
Also need pushrod and lifter weights.
All info needed in grams. thanks in advance.
Old Jan 15, 2007 | 10:09 PM
1LESSZ28's Avatar
10 degree hardware with 4705-16 spring seats:
795-16 steel retainers
614-16 locks (+.050), 1.75" installed height
4705-16 spring seats, .062" thick
Old Jan 16, 2007 | 02:15 AM
SStrokerAce's Avatar
Best way to get all of that is buy it and check it out yourself, especially the rocker arm mass.
Bret
Old Jan 16, 2007 | 04:08 PM
1LESSZ28's Avatar
Bret
Yeah, normally I would and probably will but I am using the data to design a cam. Will more than likely use the same hardware regardless of specs though.
Old Jan 16, 2007 | 04:29 PM
OldSStroker's Avatar
What software are you using? Does it want MoI of rocker? How about stiffnesses of lifter, pushrod, rocker and valve? Resonant frequency of the spring?
I'm sure you could convert the weights to grams even if you had them in ounces or long tons.
Old Jan 16, 2007 | 06:31 PM
1LESSZ28's Avatar
EA Pro. Everything except the frequency of the spring and valve stiffness. I notice I can chose not to calculate valvetrain dynamics with EA Pro . The results are very accurate for other cam profiles I have entered (not using valvetrain dynamics I guess the program just uses optimal settings?) and I do have all of the other parameters correct except the valvetrain dynamics.
Old Jan 17, 2007 | 08:15 AM
If you don't use valvetrain dynamics you are kidding the program...and yourself. There's a lot of that going around.
Bite the bullet, buy the parts and a good scale and have at it.
HectorM52
Jul 30, 2017 11:46 AM
mightymouse383
Jul 20, 2016 07:34 AM
oldschool
Feb 9, 2016 09:21 PM
mrwz28
Jul 8, 2015 09:11 PM
KamikaZ28
May 28, 2015 12:45 AM
