Best springs for Rocker Arms
Old Jan 21, 2007 | 10:50 AM
H82GOSLW's Avatar
I'm planning on installing 1.6 rocker arms and will replace the springs while I'm at it. My question is, what type of springs should I use and should I go with a double set of springs? Aside from the rocker arms, the motor is all stock. Also, I know the valve covers need to be altered in some way. Anyone have any guidance on that? Thanks for your help.
Old Jan 21, 2007 | 11:02 AM
Z95m6's Avatar
Are you planning a cam in the future? if not i'd just go with some hotcam springs. They're cheap and a single spring is a lot easier to install in my opinion. As far as altering the stock valve covers do a search. There is a post with pictures i believe that shows exactly what to do.
Old Jan 21, 2007 | 11:49 AM
2000GTP's Avatar
Another vote for the LT4 springs, they are cheap and will get the job done if you plan on upgrading the rocker arms only.
Old Jan 21, 2007 | 01:53 PM
NJ-LE's Avatar
Smile
If you use the Crane Gold narrow body self-aligning 1.6 rollers there is no interference with the factory rocker covers. At least for the 1995 LT1.
Old Jan 21, 2007 | 01:54 PM
H82GOSLW's Avatar
Thanks for the responses. I've just did some searches on "LT4 valve springs" and can't find anything...maybe I'm searching with the wrong words? Any ideas as to where I can find these springs?
Old Jan 21, 2007 | 03:23 PM
2000GTP's Avatar
Alot of sources: ebay, Scoggin-Dickey, GM Parts Direct, or one of these guys: http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason
Old Jan 21, 2007 | 04:55 PM
Bersaglieri's Avatar
I just took off my LT4 springs for my cam swap. I'd be willing to sell them for pretty cheap.
-Dustin-
Old Jan 23, 2007 | 09:01 PM
H82GOSLW's Avatar
Still looking for springs....anyone have any for sale?
69z-28
Jan 29, 2016 10:46 PM
Sauced
Apr 12, 2015 10:18 AM
carl.froehlich
Mar 13, 2015 12:38 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
