Need advice on 3200 non-lock up convertor
Old May 11, 2003 | 08:24 PM
lt1car's Avatar
I have a chance to buy a non lockup torque convertor cheap. Please explain to be the negative and positive sides of a non lock up.
Should I just save and buy a lockup or go with the non lock up?
Thanks,
Joe
PS> Im not sure of the brand name.
Old May 11, 2003 | 08:33 PM
GhostZ's Avatar
Lock up is basically the TC engaging into a 1:1 ratio. You will feel the torque converter "slipping" until it locks up and the RPM's will drop.
With a non-lock up converter, your RPM's will remain higher than they normally would with a converter that "locks up".
If you don't mind the gas mileage and driving at a higher RPM, then I would go with it. But if this is your daily driver....I wouldn't recommend it.
That's it in short....might want to do a google search or maybe howstuffworks.com to see if they have some more in depth torque converter information.
Jeff1904
Jun 5, 2016 05:00 PM
David Dempsey
Mar 12, 2016 12:42 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
