Baer brakes
Old May 11, 2003 | 09:57 PM
J96Z's Avatar
Baer brakes
Finally installed the Baer brakes today. What a difference. Well worth the 2k Check out my sig.
Old May 12, 2003 | 01:39 AM
J96Z's Avatar
I guess no one gives a hairy rats.
Old May 12, 2003 | 08:05 AM
athens96ta's Avatar
Hey man, I care! Good for you. I love my Baer brakes!
Old May 12, 2003 | 07:50 PM
Bud M's Avatar
Yeah, brake improvements are well worth it.
Old May 12, 2003 | 08:02 PM
Johnnynsac's Avatar
I love big brakes, any pics. Love to see how they look on your car.
Old May 12, 2003 | 08:37 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
shoulda just did the C5 upgrade with good pads and made vents. then spent the extra grand on heads and cam so you could use the brakes
of coarse you wouldn't have the pretty slots and useless slots though
just my two copper coins
Old May 12, 2003 | 09:00 PM
96Z28TealM6's Avatar
Did you install the brakes setup yourself, if so how hard was it? I need mine changed quick!
Old May 12, 2003 | 09:01 PM
J96Z's Avatar
Well I didn't so oh well. I guess i just like to put the best parts on my car I can afford. Who says I can't do heads and cam too? It's only money eh? Why else do I go to work everyday?
Old May 12, 2003 | 09:04 PM
J96Z's Avatar
The install was pretty easy. Just time consuming when you do it by yourself. The back brakes required the axles to be pulled to install the Baer backing plates so plan on getting some gear oil while your at it. The kit came with braided brake lines too. Make sure you get a 12mm line wrench or else you'll round off the brake line nuts.
wannaracez28's Avatar
How to get oem air elbow on 58mm T.B.
How do you get an oem air filter elbow on a 58mm throttle body?
Old May 12, 2003 | 09:27 PM
rskrause's Avatar
Moderator
Trey: you rascally iconoclast you! (vocabulary lesson #38)
I agree, the C5 upgrade is the most cost effective. Even me (who has spent megabucks on his car) has them. But I am glad J96Z like his new brakes, useless holes/slots non-withstanding.
Rich Krause
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
maverickmk
Sep 1, 2015 09:17 PM
