LT1 guys opinions about LS1
Old May 11, 2003 | 10:31 PM
Blk94Z28LT1's Avatar
Just had a thought, is there alot of room to modify a LS1 engine. Everybody says the heads flow great, so is there any room for improvement there? If the LT1 can get close to the flow potential of the LS1, can we hang with them or beat them? Are the LT4 heads a good start? Just wondering!
Old May 11, 2003 | 10:44 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
bolt-ons will put you close to LS1 performance, them being stock. Heads and cam on a LS1 will make from 410 to 470 to the wheels depending on how radical they went. Out of range for a heads/cam LT1. There cyc- head design is just so much better than a LT1. We run a 23 degree head while there's are 15. LS1 and LS6 heads will flow more, unless you upgrade to AFR's. I'm running AFR 210's that flow 310cfm.
You can also run more cubes out of a LS1 than a LT1. 434 or higher depending on Block applications. If I had to do it over again, Id probally go with a LS1, but I guess I could shove a 1st gen block in there with a 18 degree head and make thing even. There are just too manys ways to go, but by far a LS1 does have the advantage. Just depends on how much your willing to spend.
Neal
rideordie
Nov 5, 2019 04:52 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Rich_z28
Sep 13, 2002 03:35 PM
Red97LT1
Aug 7, 2002 05:45 PM
