whats wrong
Old May 10, 2003 | 07:41 PM
sc1twntrbo's Avatar
getting hot
last fall i instaled a csi electric water pump along with a 160 thermostat. and it ran at 160 on hwy and about 170 in city through the winter. now that summer is starting i run about 165 on hwy, but in city i run about 190, and if it gets stop and go it climbs to 210 and still gets higher. if i go to a drive through it it automatically jumps to 210 or more. it does help a bit if i turn on the ac to kick in the secound fan. but not a whole lot. also when it hits 210 it starts smelling like coolant.
Old May 10, 2003 | 09:43 PM
revtime's Avatar
It will run a little hotter in the summer, I run the stock water pump and 160 stat and my guage never gets over the the next line up from 0. Have you reprogrammed the computer for the 160 stat? Are you sure both fans are coming on? If everything checks out you might flush the system and make sure you get all the air pockets out.
Old May 10, 2003 | 10:50 PM
$hawn's Avatar
Sounds faily normal for the temp to rise when your at a stop cause of no air through the radiator, although it could be a little better. Somethings to check are that there is nothing blocking the radiator, air dam still in place, rad cap holding 18psi, and air is bledd out.
Old May 11, 2003 | 02:46 PM
sc1twntrbo's Avatar
what about the strong coolant smell
Old May 11, 2003 | 04:51 PM
$hawn's Avatar
Have you checked for leaks, Does it smell like it in the interior, if so if could be the heater core.
Old May 13, 2003 | 02:56 PM
Atilla_95_Z28's Avatar
From: As close to Kentucky as I can get and not actually live there!
My 95 does the same thing. That smell has been driving me nuts for 2 years. At first I thought I had blown a head gasket, but there is no oil in coolant or vice-versa, and I never have low coolant. I think it is coming from the vent in the overflow container's lid.
It is kinda nerve-racking, but I have come to think that it is the job of this car to drive me crazy for no apparent reason - pretty much like my wife!
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
