oil pressure gauge..problem!!!
Old May 11, 2003 | 12:11 AM
My95Z's Avatar
I got my car tuned yesterday and the guy said my oil pressure is low...the gauge is around 20 or whatever the mark is above the red..and when at wot it only goes to 40 or so...what is all of your pressure at? is my gauge bad or do I have something bad goin gon like bad main bearings or oil pump?
thanks
Old May 11, 2003 | 12:20 AM
Hawk's Avatar
go to the store and buy a mechanical pressure guage, and screw it into the back of the intake. Check the pressure to see if it's your guage. I believe minimum value is 10psi ber 1000rpm, it's in the shop manual i believe...........
Old May 11, 2003 | 12:24 AM
DarinsTA's Avatar
I have had 4 4th gen cars and all of the oil press gauges did the same thing as you describe. This is normal for these cars.
Old May 11, 2003 | 11:44 AM
My95Z's Avatar
anybody else hae any ideas
Old May 11, 2003 | 11:54 AM
Pretty much normal. I doubt you have anything to worry about. The mechanic is probably not familiar with LT1s. Your idle pressure is actually higher than a lot of people's. WOT pressure could be a little higher, but it might be the sending unit. The sending units seem to cause lower pressure readings as they age.
Old May 11, 2003 | 12:03 PM
My95Z's Avatar
thanks..makes me fell better
Old May 11, 2003 | 03:50 PM
carnutz's Avatar
You checked out my oil pressure at the meeting yesterday, Mine has always been good and I have a bunch more miles on mine than you. I have seen the electric sending unit go bad before, I would take a close look at the sender, they are reasonable so why not replace it?
Old May 11, 2003 | 10:45 PM
My95Z's Avatar
I changed my oil today with mobil 1 full syn 5w30 and it is all better
Old May 11, 2003 | 10:54 PM
chasmanz28's Avatar
Re: oil pressure gauge..problem!!!
thanks
A low pressure reading at higher RPMs can be caused by 3 things: worn rod bearings, the oil pump pickup set too low to oil pan, and debris caught in the pump pickup screen. Have you recently had an intake manifold oil leak on your car fixed (as described in above)? If so, it's probable that excess RTV sealant has broken off and got sucked into the engine where it's now lodged in the pickup screen. This will cause oil starvation at higher RPMs. Ide try the sensor if you have the problem in the future
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
