Popping when I let off the gas....
Old May 10, 2003 | 11:02 PM
96z's Avatar
96z
I know with no cats, LT's and duals or any free flowing exhaust for that matter you will get some popping when you let off the gas. I think I maybe running rich just because every time I let off the gas I get a couple pops like unburnt fuel igniting...Usually I know it only will happen after a good WOT session or even some spirited driving. This will happen now even if I barely blip the throttle....
What do you guys think?
Old May 10, 2003 | 11:58 PM
surfinmud's Avatar
I get that "popping" on decel too. I only have a high flow cat and flowmasters. I'm not exactly sure what causes it, but I like it.
Old May 11, 2003 | 12:10 AM
neil350's Avatar
Poping you hear is the exhaust gas' relighting, they do it even while stock a little, but from your exhaust or better words, there lack of, will deff do it more.
Old May 11, 2003 | 01:30 AM
GeneralZ's Avatar
Its normal...my car has been known to shoot flames out the pipes when it happends
Old May 11, 2003 | 04:02 PM
fbird95's Avatar
This is normal even for stock, more common with more open exhausts. Manual trans cars tend to pop more than autos.
Old May 11, 2003 | 08:25 PM
Brent94Z's Avatar
Super Moderator
I didn't drive my 94 for a couple months once and when I did it sounded like an explosion under my car when I'd let off the gas. Turned out my gas went bad on me. After I filled up and diluted the bad gas with good gas, explosions went away
So, is it possible you may have got a bad batch of gas? If it has been going on for months then probably not but you didn't say if it just started or not
Nayr
Mar 3, 2023 08:34 PM
Aaront810
Aug 29, 2020 09:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
Toxintwins
Sep 11, 2015 11:13 AM
