damaged catback, dented, replacement needed??
Old May 10, 2003 | 03:18 PM
Hawk's Avatar
Basically, i hit something really hard with my right rear tire, the tire went so high it got cut on the fender and i looked underneath and found that the axle went up and smacked into the exhaust pipe that goes over the axle. It put a nice dent in it, prob around 1/2" deep in the center and just rounded out on the sides, since the axle itself is rounded. So it's a smooth little pit with 0.5" center deep from the outside wall of the pipe. Does this warrant replacing, am i losing that much power?? I don't think i am, reason i ask is becuase ppl make a big deal about mandrel bent pipes, 3" IPIPE over the 2.75", etc. Thanks in advance.
Old May 10, 2003 | 11:01 PM
Hawk's Avatar
TTT
Old May 11, 2003 | 12:32 AM
Hawk's Avatar
TTT
Old May 11, 2003 | 12:35 AM
Sparty7's Avatar
i cant cay for sure......my first thought was to try to bend it back with clamps and grips but that could make it worse! i dont know what to tell you, sorry
What in the world did you hit ?
Old May 11, 2003 | 12:38 AM
Hawk's Avatar
http://web.camaross.com/forums/showt...eferrerid=9637
Thats what happened, .
Thought it was just the tire and wheel damage, now i have a bent exhaust pipe and some kinda rattle from the right year on startup, gotta track that down too.............
Old May 11, 2003 | 03:54 PM
EviLBoX's Avatar
I don't think it's worth replacing. On several of SLP's catbacks they already have a "dent" in the pipe that goes over the rear axle to clear it. I doubt you'd see any gain in hp replacing it.
Old May 11, 2003 | 04:56 PM
Hawk's Avatar
well, i was so paranoid i actually calculated it out.
3" pipe has area of pi*1.5^2=7.068 in^2
i measured the dent and it is approx 0.5" deep and i'll estimate it at a half circle since it's smooth. So with the dent the area is pi*1.5^2-0.5*pi*0.5^2=6.676 in^2
then i said, wtf, lets say if i had the stock 2.75" pipe in there, the area would be pi*1.375^2=5.939
I can sleep at night now,
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
cmdeshon
Dec 12, 2014 10:51 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
