I've got a problem HELP ME
Old May 11, 2003 | 07:06 PM
Mr_Superman's Avatar
Finished my lt4 hotcam kit and headers plugs/wires...after completion of everything seems like dead plug or somethin.....
With pedal on the floor (brake torque) in drive it is only going to 2000rpms...Seems as if it may be out of time of there is a dead plug or crossed wire or somethin. Or maybe even my valve lash....just aggravated about it right now and just wanting to get some opinions!
Old May 11, 2003 | 08:52 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
Sounds like the timming is off. How did you adjust the rockers? They may be to tight aswell. Id also check your firing oder. Maybe you crossed a couple of wires. Did you change the plugs out? If so, maybe you cracked a couple. Just some things to look at. Remember, on the opti the firing order is written down on the side of it. I usally write it down on the front of the opti with a perment marker. Just makes things easier.
Just reread your post. On the rocker, You want to tighten the intake valve just when the exhaust valve starts to open. When the intake starts to close you tighten the exhaust. I like to go a 1/4 past zero lash. I installed a starter botton mounted to the fire wall of the car. this makes it easier to turn the motor over when adjusting your rockers. just some helpful tips on making the job alittle easiter.
Neal
Old May 11, 2003 | 10:30 PM
thanks for the info...i was checkin plugs/wires and found one roasted wire and one cut wire....thats great! but so much for the 80 super conductor wires! anyway hopefully that will be my problem and i can b happy! but if not i'll be right back here again
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
