Follow up on LT1 Starters. Which one?
Old May 12, 2003 | 12:51 PM
zhevy-1's Avatar
I'm undecided on which starter I need to get. After doing a little search here, looks like the CVR and the LT4 are the front-runners.
Basically, I'm looking for one that won't be a hassle to install, like grinding stuff off, shimming, etc... I want one that is reliable, and trouble free. What do you guys recommend, who has what?
Thx-Goose
Old May 12, 2003 | 01:57 PM
93Z4ME's Avatar
I spent a day trying to track down availability and options for LT4 starters (153 tooth Nipendeso Style-High Torque, Straight Bolt Pattern) and found the following:
GM New AC Delco # 10455709 $304.02
Autozone Duralast #17123 $210.99 (exchange)
Pep-Boys Pro-Start #17124 $169.99(exchange)
Napa Nipendeso #17579 $199.99 (exchange)
Summit Power Master #9202 $199.99 (need wire mod?)
* note: some places may not accept your LT1 starter as exchange on an LT4 type (they won't look the same) clerk ignornace will work to your benefit.
I did not check Sam Taylor prices, that may be the best bet.
Old May 12, 2003 | 02:34 PM
zhevy-1's Avatar
Right on, man. Thaks for that good info. I'll check it out.
Old May 12, 2003 | 03:44 PM
Mtrhds94Z's Avatar
I think one is about 160 ish from Jason Cromer.. DEFINITELY NOT 300+...
Old May 12, 2003 | 03:53 PM
shocktrp's Avatar
MY LT4 starter was $158 shipped from Sam Taylor (haven't got around to installing it yet - I have bigger problems).
Old May 16, 2003 | 07:26 AM
TDog's Avatar
This may be a dumb question but I'm learning here...
I've been thinking of replacing my stock LT1 starter...will the LT4 starter work perfectly on my stock LT1...
Thanks,
T....
Old May 16, 2003 | 07:33 AM
Bastardcat's Avatar
Correct, there are no modifications required to install the LT4 starter.
Old May 16, 2003 | 07:52 AM
TDog's Avatar
Thanks...
Old May 16, 2003 | 07:57 AM
mobleman's Avatar
There could be some interference with the lt4 starter and shorty headers..
My starter rubbed against on the the tubes on my Mac Headers.. A little grinding and the problem went away..
Old May 16, 2003 | 08:40 AM
Xscream's Avatar
What is the point to goto a LT4 starter over a stock LT1 starter?
If you guys are looking to save money just use a S10 starter 49.95 at checker
Old May 16, 2003 | 08:45 AM
jim88iroc305's Avatar
It's not about saving money. The LT 4 unit is a "heavy duty" unit when compared to the LT 1 unit.
Heck, just doing a side by side look gives one the impression the LT 4 unit will last forever.
Old May 16, 2003 | 10:00 AM
SloMofo's Avatar
I have an LT4 starter in my car and no complaints
DirtyDaveW
Dec 1, 2016 05:37 PM
HectorM52
Jun 23, 2016 08:42 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
