Stock Cam Specs
Old May 10, 2003 | 12:41 AM
jd94z28's Avatar
Stock Cam Specs
What are the stock cam specs, i.e. lift and duration.
Old May 10, 2003 | 07:40 AM
Josh-'04 GTO's Avatar
I think it's 203/207 .447/.459 116.5 but I'm not 100% sure, just doing this off the top of my head.
Old May 10, 2003 | 07:47 AM
n2ceptor's Avatar
.450 intake .460 exhaust on my '93 Z......
Old May 10, 2003 | 08:15 AM
rskrause's Avatar
Moderator
I have seen the following specs quoted:
'93-'95 203/207 @ 0.050" 0.450/0.460" 116LSA
I have also seen the spec for the '95 and '96 quoted as:
200/207 0.447/0.459" 117LSA
Not sure how accurate these are though.
Rich Krause
Old May 10, 2003 | 09:24 AM
Smokn '94 Z's Avatar
Issued: 3 March 1994
Revised: 6-8-98, 8-3-98, 7-1-99, 6-26-01, 01-04-02, 6-11-02,9-11-02
Bulletin #: CHEV-94 Page 1 of 1
Specifications for the 1994 Chevrolet engines.
H.P. Disp. C.R. Ind. Make Model/Transmission Manifold R.R. Lifter Head cc Notes
160 207 9.0 PFI Roch NA 10118661 upper 1.5 H 50.35 1 10137051 lower
200 265 10.7 PFI AC/Roch 12552137,10108630 1.5 H/R 45.5 2
260 350 10.1 PFI AC/Roch 12552138 1.50 H/R 62.0 2
275 350 10.5 PFI AC/Roch NA 10108471,10108629F 1.50 H/R 51.9 2
10108630
Notes
1 - Throttle Bores - 2.52" (64mm)
2 - Throttle Bores - 2 x 1.88" (48mm)
Deck Piston
H.P. Disp. Cl Type Height Vol Valves Cam Lift Springs
160 207 .011 Flat 1720/1415 393/408 Outer w Damp
200 265 .015 Flat w/notches 1840/1500 447/459 Outer w Damp
260 350 .025 Flat w/notches 1940/1500 449/460 Outer w Damp
275 350 .015 Flat w/notches 1940/1500 449/460 Outer w Damp
H.P. Disp. Gasket Head Cast
160 207 .042 14031327
200 265 .025 12529742,10208890
260 350 .029 14088526
275 350 .047 10205245,10128374,10207643,12551561,10207640
canbaufo
May 25, 2015 12:01 PM
Noer
Feb 28, 2015 11:29 AM
blac94Z
Feb 18, 2015 11:36 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
