Mufflex y-pipe with KBDD SFC's on a convertible??
Old May 10, 2003 | 06:48 PM
94ZVert's Avatar
This is sort of a repost. Has anyone gone the longtube and mufflex y-pipe route on a convertible and then try adding Kenny Brown SFC's? The reason I ask is that after installing the Y-pipe I had to remove the crossbrace in order to get it to fit up in there. And since that's where the SFC's tie into, coupled with the fact that the Y-pipe takes up so much room, I'm concerned that I may not be able to use my new SFC's. Anyone have any experience with this? Thanks.
Old May 10, 2003 | 10:06 PM
PoorMan's Avatar
Hey
Thanks for the reply to my msg I sent you. May want to try over at www.chirpthird.com also. They have a 4th gen conv. section though it is not as active as here.
Jeff D.
Old May 10, 2003 | 10:16 PM
LPE Z convt's Avatar
I have kbdd subframes and LTs with mufflex y-pipe everything fit great all i had to do was cut a corner of the stock brachet off because the y-pipe hit their that was it I have pics if you want to see them let me know
Old May 10, 2003 | 10:54 PM
94ZVert's Avatar
Please send me those pics. Thanks!!
Old May 10, 2003 | 11:14 PM
PoorMan's Avatar
Hey, send me the pics too please. Like to see the y-pipe mounted.
thanks
Jeff
Old May 11, 2003 | 08:02 AM
94ZVert's Avatar
I received the pics, but your undercarriage looks different than mine. Is yours an M6? Also, did you have that red "crossbrace" fabricated to tie in your KBDD's? Thanks.
Old May 11, 2003 | 12:09 PM
My car is an auto if you want give me a call and i can give you the name of the driveshaft loop i will have to look I had KB install these and they did a great job..#765-426-9944 cell or leave your # and i will call you
Old May 15, 2003 | 01:40 PM
PoorMan's Avatar
Looks like the Metco Drive shaft loop you got there. It looks like adding LT's, Mufflex y-pipe, 4inch to 3inch down tube, and borla cat back will be a complete bolt-in setup using this drive shaft loop for us conv people. Thxs for the pics.
Jeff D.
jbert55
Oct 31, 2015 03:52 PM
jbert55
Aug 3, 2015 05:49 PM
detroitmuscle
Jul 31, 2015 04:21 AM
ricks95TA
Jul 23, 2015 12:59 AM
ricks95TA
Jul 22, 2015 10:15 PM
