Cat Converter
Old May 11, 2003 | 09:41 PM
CamaroGuy22's Avatar
Cat Converter
Alright, i did a search, came up with nothing.
How good is the stock converter? How much difference would it make if i switched to a free flowing cat?
In about two weeks i should have K&N FIPK, SLP Y Pipe, SLP Loudmouth installed on the car. I dont really feel like spending any more money if its not necessary.
Old May 11, 2003 | 11:00 PM
norcalstreet's Avatar
I've never seen a dyno comparing a stock and high flow cat. You're more than likely to gain a few HP with a high flow cat but it would be cheaper to simply gut the cat.
I would recommend just get some brqackets installed so you can swap in an off road pipe whenever you want.
Old May 12, 2003 | 09:18 AM
EviLBoX's Avatar
Unless your current cat is clogged, I don't think you're going to see enough of a gain to justify the cost of a high flow cat. I'd just wait until your cat dies or go ahead with an offroad pipe since it's cheaper.
Old May 12, 2003 | 01:24 PM
I did not think that the cat is a major source of restriction, I got a y-pipe, i wasnt sure about purchasing that also when i am not installing headers but some people said that the y pipe should free up a good 10 rwhp? I got a new slp y pipe for 80 dollars shipped, so it wasnt that expensive.
Old May 15, 2003 | 07:26 AM
Ok where can i find a good off road pipe, i cant fine one.
Old May 15, 2003 | 09:18 AM
GREGG 97Z's Avatar
Thunder Racing has two available for a 95.
thenewkid
Apr 12, 2015 07:42 PM
jasonduaine
Apr 1, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
Dec 1, 2014 08:08 AM
thenewkid
Nov 27, 2014 09:41 AM
