rear end carrier help
Old May 10, 2003 | 11:53 AM
chevy1963's Avatar
ok this is the problem. I'm going to change from a 2:73 gear to a 3:73 gear. this kid at a local atuo shop told me in order to do that i would have to replace the stock carrier which I wanted to use for a 3 series carrier?
Is the carrier in a z28 with 2:73 gears a series 2 and do i have to buy a new series 3 carrier or can I use a spacer on the the stock on?
Old May 10, 2003 | 01:49 PM
anaik's Avatar
Correct, you have a 2 series. You can buy 3.73's for a 2 series carrier. Look in Jegs or Summit. They have a thicker ring gear so a spacer is not required.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
