ring and bearing questions
Old May 10, 2003 | 01:55 PM
Cheekster96's Avatar
hey gang, how goes it???
these questions are to the people who have done a 383 buildup on their LT1.
i need to re ring several of my pistons due to washing of the cylinders when the plug wasnt firing..i didnt know untill i put a scanner on the car to see that i was not pulling on two cylinders..i tried to reseat them but no avail and now im sick of the smoke coming out from the tailpipes.
i have a set of Luntai racing pistons in there and was curious what kind of rings i should put in..i was looking at the Childs/Albert (4.030 bore with 1/16 top second ring & 3/16 bottom ring). looking for a file fit..
also..i am confused about the differences between large and normal journel sizes..my LT1 maintains the two bolt mains, never up graded to four bolt. what kind (size) of main brgs would be recommended..
the rods are 5.7" in length (Lunati). again, what brand would work here.
the car is not race driven but i like to get on it from time to time, and is only driven occasionally.
i am sorry for the long post, just have lots of questions and not sure how to properly say them...
thanks.
Lee
96Z 383
Old May 10, 2003 | 02:00 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: ring and bearing questions
thanks.
Lee
96Z 383
you can't oversize or undersize rings/bearings
if you bored 10 over, you get 4.010 rings
bore 30 over and you get 4.030
same thing with the journal. if you crank was turned, you get oversized bearings. if not, stock size.
bearings and rings dont effect drivability (well unless they aren't working right )
Old May 10, 2003 | 04:11 PM
Thumbs up
thanks for the input!!
Lee
96Z 383
1963SS
Feb 6, 2015 10:05 AM
ChrisFrez
Feb 1, 2015 08:26 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
