Will a 93 AC compressor work on a 94?
Old May 10, 2003 | 04:09 PM
SlickLT1's Avatar
WIll the AC compressor from a 93 Z28 work on a 94 Z28. THank you Cory
Old May 10, 2003 | 06:26 PM
Dave 96TA's Avatar
AFAIK they should be the same. The LT1 block itself should be the same in 93-94 so the bolt holes for the bracket will be identical. What I would do is visit rockauto.com or gmpartsdirect.com and check the part numbers. If your number on the 93 is the same as what they show for a 94, you have your answer!
99TransAmWS6
Feb 12, 2015 07:23 PM
alphaauto
Feb 5, 2015 05:25 PM
alphaauto
Jan 23, 2015 07:42 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Snoman73
Nov 17, 2014 07:22 PM
