383 and catalytic convertor...
Old May 10, 2003 | 08:54 PM
yorkie's Avatar
I live in a state and county with no emmisions testing, would it be better to gut the cat? I just built this motor and am having PCMforless do the pcm reprogram, he said I could gut them or not on the same computer he is sending... The car smells like rotton eggs even at idle.
Old May 10, 2003 | 08:56 PM
yorkie's Avatar
also the car had 129,000 before rebuild with...
stock muffler, probably needs to be changed, Huh?
Old May 10, 2003 | 09:52 PM
Josh-'04 GTO's Avatar
You really should post your signature, so that we can see what vehicle/mods we are talking about. If you're building any kind of real 383, than the stock manifolds and cat back need to find the nearest dumpster. The cat should be swapped out for a high flow one, or just gut it if you have no emissions worries.
Old May 10, 2003 | 09:55 PM
yorkie's Avatar
yes I know...
383, hot cam, stock manifolds, stock 129,000 muffler and 129,000 cat. I would love to put headers and all but out of money right now, gutting cost only time.
Old May 10, 2003 | 09:57 PM
yorkie's Avatar
think I will gut it for now.....
until I can get a real y pipe and headers or even better LT's.
Old May 11, 2003 | 11:36 AM
yorkie's Avatar
also How can I know if the O2 sensors...
are working or not? Other than a scanner???
Old May 11, 2003 | 11:37 AM
yorkie's Avatar
Is the rotton egg smell....
The catalytic convertor not working right?
Old May 11, 2003 | 04:51 PM
Re: also How can I know if the O2 sensors...
Really no other way I know of. Use of a multimeter fries the sensor. Best way is with a scanner so you can monitor the readings and crosscount activity.
Old May 11, 2003 | 04:53 PM
yorkie's Avatar
I remember reading..
somewhere a digital multimeter can work on very low Ohms?
colts0455
Sep 22, 2015 02:03 PM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
