Gear change on a 93
Old May 10, 2003 | 09:24 PM
Gripenfelter's Avatar
Gear change on a 93
If I was to change the gears in my car I just have to adjust the speedo right?
I don't have to re-program the PCM right?
I have a 700R4.
Old May 10, 2003 | 09:42 PM
Fastbird93's Avatar
You have to get a speedo recalibration box and splice it into the wiring harness. It's like $80 from SLP, but I caught wind of a rumor that they quit selling it. The speedo can't be reprogrammed by doing a computer chip.
Old May 10, 2003 | 09:47 PM
Can't you get a gear clip for the speedo cable from GM that would make it 3.73s?
Old May 11, 2003 | 01:36 AM
GeneralZ's Avatar
Just change your speedo geers....it'll save you a lot of money compared to the SLP recalibrator
Old May 11, 2003 | 02:45 AM
carnutz's Avatar
Just pull the tail housing off and the driven gear/sensor the plastic gear on the mainshaft is stubborn comming off. swap both gears and this will be hunky dory.
Old May 11, 2003 | 11:23 AM
faded93bird's Avatar
thats what i did and it worked great
got mine for less than 30 bucks from slp when i got my torsen
oh and it is a PIA to get the main shaft gear off have fun cause its way cheeper
Old May 11, 2003 | 03:55 PM
Awesome thanx guys!
PCLZ28
Dec 24, 2015 05:19 PM
David Dorris
Jan 17, 2015 08:10 PM
Jul 4, 2005 05:00 PM
