LT4 crank sprocket install did search
Old May 10, 2003 | 11:35 PM
LPE Z convt's Avatar
Can anybody tell me info about how to remove and install the crank sprocket for the LT4 extreme duty set up tools etc I am unsure if it needs to be pressed on or ?
Old May 10, 2003 | 11:51 PM
bunker's Avatar
same as any crank sprcoket I'd assume, take a really bit socket to fit over the crank & bang the socket which will drive the sprocket on, then when the balancer/hub goes back on, it will acctually push the sprocket in all the way if it had a bit to go cuz the hub all the way on still pushes firm up against the sprocket to make sure its in & doesn't come off so if hub is on all the way then its all good, but yeah do that.
Old May 10, 2003 | 11:53 PM
All crank sprockets are a press fit. Removal is done with a 2 or 3 claw puller. Installation can be done with a piece of pipe or something to drive it on flush.
LeftoverChinese
Jan 14, 2024 03:03 PM
HectorM52
Jun 23, 2016 08:42 PM
Chevyguy358
Jan 28, 2015 08:04 PM
Queens94z28
Dec 20, 2014 09:11 PM
