Car starting problems
Old May 10, 2003 | 04:23 PM
Superfly95Z's Avatar
Question Car starting problems
I posted a few days ago about my ignition getting stuck sometimes and now I have some more info on this problem I am having. I have noticed that now if it does get stuck, it is only on a hot start, never on cold starts. Also, occasionaly I cannot start my car on hot starts either. Cold starts are perfect. Occasionally on a hot start though, my motor wont even turn over. It acts like your car does when you have a dead battery, nothing happens except I hear the fuel pump and my guage lights and radio come on, but starter doesn't turn or anything. What could be doing this? Again, this only happens on hot starts, other than that it is fine. I have no other problems with the car, good battery voltage and all that. Please help. Thanks
Joel
Old May 10, 2003 | 05:29 PM
Sparty7's Avatar
yes.......someone please help!!!!!!
mine starts great on cold starts but after is warm it might turn over for 5 seconds, shut it off, turn over for 5 seconds, shut it off, and then try again........start fine. WTF!! please help us
Old May 10, 2003 | 10:23 PM
Fatdog's Avatar
Cool
After I had the intake oil leak fixed(gasket),my starting problems went away.My02
Old May 11, 2003 | 12:10 AM
Sparty7's Avatar
well good then, i have a oil leak at the waterpump and intake that are both getting fixed this coming week.....so it should be starting right up after that. thanks
Old May 11, 2003 | 12:12 AM
Possibly the starter is failing when it is hot. You might check connections at the starter, too.
97SSdude
Dec 31, 2014 07:43 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
USAirman93
Nov 24, 2014 03:37 PM
teedoff59
Aug 8, 2002 01:36 AM
