ARP head bolts and LT1 torque specs
Old May 12, 2003 | 03:33 PM
quicksilver97ta's Avatar
What torque specs would you use for LT1 heads with ARP bolts? The ARP's are much harder bolts so they wouldn't stretch the same as GM stock, thus the xxft/lb followed by an additional xx degrees may not be accurate. Does that make sense?
What are some other SBC torque specs that dont use additional degrees, just plain ft/lbs?
Old May 12, 2003 | 03:40 PM
chevyguy3's Avatar
use the torque specs ARP includes with thier bolts
Old May 12, 2003 | 03:42 PM
Hoostie's Avatar
I torqued mine to I think 80 foot pounds, and I never had any problems. The stock bolts are torque to yeild, and the ARP's arent, so you dont have to do any addition turning once they are torqued down.
Old May 12, 2003 | 03:49 PM
So they will send specs with the bolts? Cool, they are already on their way then.
Old May 12, 2003 | 04:31 PM
Dr.Mudge's Avatar
Not every year LT1 has TTY head bolts. In FACT I have used mine now 5 times, not counting the original factory installation, which would make it 6. Car is my daily driver once again and runs great.
So far as I recall only 96+ got TTY, but I dont know for sure.
Old May 12, 2003 | 05:49 PM
thewinner's Avatar
I have the same questions. What tq values do you guys use on each pass for these arp bolts and with what lubricant?
the table arp gives is slightly confusing!
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
