Car tries to die with AC ON!!!!!!!!!
Old May 10, 2003 | 06:26 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Dont know why but when i turn the AC on all the way my car idles really low and acts like it is trying to die. I also get a knock retard reading from .1 to 2.0 when this happens, do you think it is false knock and or are these things related. Thanks for any imput.
Chris
Old May 10, 2003 | 06:29 PM
Dave 96TA's Avatar
hrm things that come to mind:
A/C compressor getting worn out and the bearings ready to sieze?
Vacuum leak?
Bad power/ground to the blower motor taking too much voltage from your system and affecting your spark?
Long shot but maybe something IAC related?
Old May 10, 2003 | 06:34 PM
I think it may have something to do with the compressor because my AC HAS been acting up lately. I guess i will just have to go get a free AC check done. Thanks though, any other ideas?? Oh and whats an IAC????
Chris
Old May 10, 2003 | 10:26 PM
$hawn's Avatar
IAC, is idle air control valve, it's on the passenger bottom side of the throttle body if you didnt know.
Old May 11, 2003 | 03:26 PM
Dave 96TA's Avatar
To add to Shawns post- the IAC is a little check valve essentially that lets enough air into your throttlebody to hold a stable idle while you're at 0% TPS (throttle position).
Old May 11, 2003 | 04:41 PM
fbird95's Avatar
I had a similar problem with my car at two points in time.
1) when the alternator was about to die
2) this one shocked me, When my clutch was slipping badly and i needed a new clutch. After i got the new clutch the ac is much happier doesnt want to stall the car at an idle. I guess the extra strain on the engine causes the clutch to slip even more.
Old May 11, 2003 | 05:59 PM
I have a new clutch, maybe its the alternator. About how long do they last on our cars?
Chris
Old May 12, 2003 | 01:10 AM
fbird95's Avatar
There is always jokes about getting a new alternator with your oil change or with a tank of gas, or even in the frozen section at Acme. Jokes aside, they are not known for being strong, usually they last between 30,000-60,000 miles.
Old May 12, 2003 | 09:36 AM
Being that my car just hit 62K then i might be looking at a new alternator then....................another part.
Chris
Old May 12, 2003 | 08:29 PM
fbird95's Avatar
Its just the way of the F-body, its cool though cause it only takes about a half hour to swop the alternator and you get money back for the core charge.
Old May 12, 2003 | 08:38 PM
n2ceptor's Avatar
check it first, with the car running, the voltage at the battery should read around 14.2 volts....
Old May 13, 2003 | 01:47 PM
My scanmaster is telling me 13.5 or 13.6. Is that a sign of the alternator going???
Chris
bfmv13trivium
Jan 14, 2015 09:57 AM
ModdedNerd
Dec 18, 2014 10:52 PM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
