Who makes adapters to run old style valve covers on LT1
how makes adapters to run old style valve covers on a LT1 motor. I have changed my setup and im runing a solid roller cam and used .100 longer vavles and now my B&B valve covers will not fit. i have seen a few pics of guys runing tall old stlye vavle covers so something has to be out there.
Mike
Mike
Summit has them, they're made by Trick Flow and cost $99.
Part #TFS-31500811
http://store.summitracing.com/defaul...t=TFS-31500811
Part #TFS-31500811
The perimeter bolt conversions for the center bolt heads that I have seen ALL leak like seives. You can get centerbolt covers like the Moroso aluminum sheet metal ones that are tall enough for a set of Jesel or T&D shaft rockers.... no need for the perimeter bolt conversion. You do need to find one with the alternator dimple if you still have it in the stock location. Or you can have a shop cut and weld for clearance.
well i just now bought the madman low mount alt bracket but the one i got was not cut correctly but madman sent me a new one and now i cant find the spacers my wife is a clean frreak and i guess trashed the spacers. also do youknow anyone that has pics of the low mount alt on the car.
thanks for the info on the spacers i currently have the alum B&B valve cover and I had them notched but they will not work do you have a part number on the moroso ones
Jul 4, 2005 05:00 PM
