Bleeding My Release Cylinder?
Old May 10, 2003 | 11:42 AM
Chris9528's Avatar
I changed my slave cylinder to cure my cars clutch problem and i tried bleeding it according to the hayes manual but it makes no sense. anyone who can tell me the proper way to bleed the cylinder on a 95 z28 which has no bleed screw, (98 and up come with the bleed screw..thank you gm). please let me know, im changing the master cylinder on monday. hope someone can help me.
Old May 12, 2003 | 09:29 PM
TW95Z's Avatar
GM now makes a nice replacement kit if you need to replace anything with your clutch hydraulic system, you just replace
everything. It comes complete from reservoir to master to slave _Filled_ with fluid so you don't even have to worry about bleeding
the system after installation. It's GM 12559912.
To bleed the system, pour fluid in the reservoir and before attaching the slave to the bellhousing, hold the slave with the plunger pointing down and push the plunger in several times to bleed any air out. Once I stopped seeing air bubbles the bleeding is complete.
Hope that helps if you still needed it,
Formula Steve
Sep 19, 2023 08:31 AM
jayblev95
Sep 26, 2015 09:44 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
NewsBot
Sep 14, 2015 02:02 AM
jackpawt883
Sep 10, 2015 08:53 PM
