People w/ QA1 in the front...
Old Apr 5, 2004 | 07:17 PM
Mr.Whitey's Avatar
...what shock/spring combo do you use in the rear? Fred's page on the shock install has a QA1 rear shock part number but what QA1 rear spring would go w/ this rear shock, if any?
How does the QA1 front drag spring handle under normal driving conditions and cornering? Is it a true drag spring or what?
How would stock LS1 springs work with either the QA1 front or rear shocks?
Old Apr 5, 2004 | 07:45 PM
aram's Avatar
I am using stock rear LT1 springs and qa1 shocks in the rear. I think that's the recommended setup.
Old Apr 5, 2004 | 08:50 PM
chesee48's Avatar
same here
Old Apr 6, 2004 | 05:25 PM
Mr.Whitey's Avatar
Thanks, that saves me some money. How do the QA1 front springs handle on the road?
Old Apr 6, 2004 | 05:26 PM
IllusionalTA's Avatar
The springs are just as good as a stock set from what i have exp...
Old Apr 6, 2004 | 10:00 PM
Mr.Whitey's Avatar
RX Speed Works
Oct 1, 2015 10:19 PM
Beave2780
Sep 23, 2015 12:37 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
