SLP LM problem
Old Apr 5, 2004 | 10:43 PM
Steve94Z28's Avatar
SLP LM problem
Ever since I installed my SLP LM exhaust about 1 month ago, I have had no problems till now. The hump in the passenger side floorboard, where the cat is under it, seems to rattle. I assume its the actual cat and not the floorboard. But it only seemst to do it when I am letting off the gas from about 3000 rpms, if I let off any lower than that it wont do it, I assume thats because of a certain tone that causes it to rattle. Well I checked the bolts where the exhaust system bolts up to the cat and they are as tight as they were when I put them on, I can't even tighten them anymore. Anyone know what it could be?
Old Apr 5, 2004 | 10:50 PM
1msfyter's Avatar
ahhh the Loudmouth drone. 2000 rpm it will drone. Also stainlesds steel expands and contracts as it heats up. Gotta tighten up the nuts after a few heat cycles. As for the drone I replaced my LM hollow resonator with a dynomax race bullet . EXACT fit plus it has some batting/insulation inside that rids you of the drone. It costs about $100 to have one installed.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
novaiiman
May 15, 2016 11:36 AM
racecarz28
Mar 30, 2015 09:55 PM
