TB Bypass
Old Apr 5, 2004 | 09:18 PM
99BlackTA's Avatar
TB Bypass
Is there any special way to do this on a 1994 rather than any other year? I've heard that on the 1994 you are connecting the two lines and on other years you are relocating one line and leaving the other disconnected. What exactly do I need to do? Anybody have pics for this year?
Old Apr 5, 2004 | 09:37 PM
krispy's Avatar
there are two tubes
need a 3/8" brass connector and 2 hose clamps
the one pipe is on the right side going to the lower right (looking from top), the other is on the left side near the back of the TB going straight down, PITA to get that one off if the clamp is faced towards the back, just 2 screw drivers and bend the **** outta it in that case
Old Apr 5, 2004 | 10:10 PM
19formula94's Avatar
i got a picture guide, i'll try to find it when i get home and post it if someone doesnt beat me to it
Old Apr 6, 2004 | 12:19 AM
http://www.geocities.com/MotorCity/6647/ta93/tbody.htm
should help a little
Old Apr 6, 2004 | 01:00 AM
Bud M's Avatar
http://f1.pg.photos.yahoo.com/ph/bud...&.dnm=d8f4.jpg
Remove the two coolant hoses from the throttle body and join them together with a hose connector.
Don't forget to place towels under the hoses/throttle body so the opti stays dry.
Bleed the cooling system when you're done.
Old Apr 6, 2004 | 12:10 PM
99BlackTA's Avatar
Thumbs up
Thanks for the info guys. I got one more question. I went to the local autozone and all they had was the plastic vacuum connector for a 3/8" hose. Will it work or will the plastic melt with the high heat from the coolant? I ended up buying it anyway just incase it will work but receipts always help out!
Old Apr 6, 2004 | 01:27 PM
ppmz28's Avatar
I just done this yesterday. I used the 3/8 plactic one and it worked better than the brass ones I was trying to use. Make sure you get the right size and tighten it down very very good. Yesterday I didn't tighten it down good and the 3/8 connector wasn't the exact same size on both sides and it sprayed anit-freeze everywhere. Probably ruined my opti, who knows??
Old Apr 6, 2004 | 01:44 PM
97firechicken's Avatar
but heres the deal is it really worth it?
Old Apr 6, 2004 | 01:48 PM
99BlackTA's Avatar
Cool
I just went out there and really took a look at it and what do you know the damn previous owner already did it! Oh well saves time and money for me!
Old Apr 6, 2004 | 08:19 PM
Bud M's Avatar
I would never use plastic. Who knows how long that will hold up?
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
colts0455
Sep 2, 2015 12:41 PM
