Timing cover gasket question
Old Apr 6, 2004 | 05:57 PM
slmdgmc's Avatar
I am just putting the timing cover back on and want to make sure everything is correct. I had a brand new timing cover with new optispark and crank gaskets installed in it. Used a felpro cover gasket on the outside along with a little bit of ultra copper rtv on the inside and outside of the seal. Also put just a little rtv in the corners of the oil pan gasket also. Now the optispark only has around 2000 miles on it, and the 2 seals on the shaft looks good. Just wanted to make sure I am not missing any other seals? Thanks.
Old Apr 6, 2004 | 07:32 PM
Dave88LX's Avatar
Aren't there 3 seals in the timing cover?
Crank
Water pump
Opti
Old Apr 6, 2004 | 07:33 PM
slmdgmc's Avatar
Oh yea, the w/p seal is blocked off because of the electric waterpump.
Old Apr 6, 2004 | 07:47 PM
Dave88LX's Avatar
What did you use to block that off?
I need to do that too mine as well with my elec WP...
Old Apr 6, 2004 | 10:25 PM
slmdgmc's Avatar
I ground the back of the timing cover flat and used two washers, a nut and bolt, and some ultra copper RTV.
*Emilia*
May 13, 2015 09:05 AM
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
Snoman73
Nov 17, 2014 07:22 PM
