383 Stroker times?
Old Apr 4, 2004 | 07:32 PM
Briank8811's Avatar
383 Stroker times?
Here are the mods in my 94' camaro z-28. Any estimated 1/4 mile times/speeds at sea level?........HP??
383 stroker built using a scat cast steel crank, H-Beam rods with a fully balanced rotating assembly and keith black pistons
Pace performance full exhaust system (3 inch with shorty headers)
Cam with a 280 intake duration at .443 lift
sub frame connectors
new clutch(6 speed)
new p245 sport tires
(assume good driving, 80 degree weather(ORLANDO), and generally good track conditions and stock weight with 140 pound driver)
Old Apr 4, 2004 | 09:17 PM
Briank8811's Avatar
Anyone got any estimates?
Old Apr 5, 2004 | 07:50 PM
Briank8811's Avatar
2nd night and no answers? Guesses?
Old Apr 5, 2004 | 08:30 PM
Briank8811's Avatar
ANYONE???
Old Apr 5, 2004 | 08:37 PM
95CamaroZ-28's Avatar
It's hard to say without knowing more about the heads and such. Just a ballpark guess...13.0s. With a good driver...high, maybe mid 12s. It depends on traction and your heads for the most part though.
Old Apr 5, 2004 | 08:42 PM
Briank8811's Avatar
I have stock heads that have been "smoothed" by the shop as the stroker was rebuilt. They also plained the deck/heads but i dont know how much was taken away. I am running a sporty street tire that is a p245 and has a semi-soft compound.
Old Apr 5, 2004 | 11:19 PM
What kind of clutch did you go with and have you had much track experience?
Old Apr 5, 2004 | 11:43 PM
Spinner's Avatar
a 383 with near-stock heads and a stock cam? Shorty headers?
Low 13s at best on street tires.
Old Apr 6, 2004 | 02:55 PM
Briank8811's Avatar
The cam is a "performance" cam with a 280 intake duration at .443 lift
Old Apr 6, 2004 | 02:59 PM
HesterZ28's Avatar
why such a small lift cam? thats killing you
Old Apr 6, 2004 | 03:01 PM
WS Sick's Avatar
Yes most definately, the cam is waaaay to small, as are your heads. But if I were to guess on a 1/4 mile time, I'd say low 13s.
Old Apr 6, 2004 | 03:18 PM
Prorac1's Avatar
the factory cam is about .450, .460 lift. Stick with what everyone else is running for a cam. a lt4 hot cam would be beter than that. the stock heads and cam are going to hurt ya. the stroker isnt going to do anything for hp, but will increase low end torque, and lower your shift points. id say high 12s with proper tuning, but it will 60 ft like a mother. hope this helps, prorac1.
Old Apr 6, 2004 | 06:57 PM
Spinner's Avatar
Theres nothing performance about that. Promise
D1SC383LT4
Jan 1, 2016 01:56 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Killer94z
Jan 13, 2015 12:06 PM
spearous
Jan 12, 2015 11:03 AM
