Changing brake line
Old Apr 5, 2004 | 08:05 PM
CamaroBoy96Z28's Avatar
Changing brake line
I'm changing the driver's front brake line. Any tips or things to watch out for? What do I need to change the line?
Old Apr 5, 2004 | 08:41 PM
Bud M's Avatar
It's pretty easy. A flare nut wrench is better for that job than a regular open end. And you should use new crush washers on the caliper end of the hose. Plan on bleeding the front brakes when you're done.
Old Apr 5, 2004 | 08:50 PM
Ok sounds good, what size flare nut wrench do I need, 12mm?
Collector Car
Jan 5, 2015 10:58 AM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
kclarson
Aug 22, 2002 04:04 PM
