best header gaskets to buy and bolts
Old Apr 5, 2004 | 10:33 AM
ppmz28's Avatar
I have a set of pacesetter LT on the way and I was wondering what is the best gaskets and bolts to buy. I plan on installing once and them being fine. I don't want to have to put new gaskets on every month or tighten bolts. Remember that my LTs are uncoated. thanks
Old Apr 5, 2004 | 10:39 AM
Fatdog's Avatar
Cool
Since nobody chimed in, I'd say do a search(up above).It seems the copper gaskets have created a big problem with leaking.Hope this helps.
Old Apr 5, 2004 | 11:01 AM
CamaroBoy96Z28's Avatar
I use Fel-Pro 1406 gaskets and ARP 1" underhead 12-pts.
Old Apr 5, 2004 | 11:03 AM
duckhead4life's Avatar
i am interested in this too
Old Apr 5, 2004 | 11:15 AM
IamN2Speed's Avatar
Agree on the Fel-Pro 1406. I have used these on 2 different motors as my second set. First set on both was copper, and I swore never to use them again.
As for the bolts, I used the standard 6pt 1" ARP header bolts. They also have a hex on the inside which is nice for some spots. I use the locking clips too. They don't seem to back up, but I'd recomend about a month after install to go back and make sure they're still tight. After that, you should never have to worry about them again.
-Keith
Old Apr 5, 2004 | 04:36 PM
ppmz28's Avatar
where can I buy the fel-pro gaskets????? and are the ARP bolts locking bolts??? where do I get these??? thanks guysss
Old Apr 5, 2004 | 05:29 PM
stereomandan's Avatar
The MR. Gasket Ultraseals are very nice too. Similar construction to the Felpro's. You can get them at Autozone (Mr. Gasket's)
Copper's didn't work for me, but I didn't RTV them like some say you should.
Dan
Old Apr 5, 2004 | 05:40 PM
Red96Lt1's Avatar
I've had no problems with my copper gaskets. I also use the Stage 8 bolts. You can get them from thunderracing. I got my gasket from sumitt.
Old Apr 5, 2004 | 05:42 PM
whiteslpz's Avatar
I use percy's dead soft gaskets and stage 8 bolts with no problems theve been on for a year and a half.
Old Apr 5, 2004 | 05:46 PM
tbsimmons's Avatar
Earl's Pressure Seals
Take your pick on any of the locking bolts.
The split locks are pretty neat, but I have the Stage-8 locking ones.
Summit #STG-8911A (Bolts)
Summit #EAR-29DA3B (Gaskets)
I have never had a leak, and the inserts are replaceable.
Old Apr 5, 2004 | 09:17 PM
kmook's Avatar
Advanced Tech Moderator
I always use 1406s, the coppers i have used in the past leak like mad.
Old Apr 5, 2004 | 09:25 PM
kevinCHOPTICON's Avatar
marking this for when i do mine
Old Apr 5, 2004 | 09:52 PM
carlos64030's Avatar
For the gaskets go with the Felpro 1406's and for the header bolts go with these: www.go-breslin.com. With this combo you can't go wrong!
Old Apr 5, 2004 | 09:58 PM
96LT14u2Nv's Avatar
i like my Mr Gasket Ultra Seals. just y .02
maybe2fast
Mar 16, 2015 09:45 AM
Queens94z28
Dec 20, 2014 09:11 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
thenewkid
Nov 27, 2014 09:41 AM
