Tail Lamp/ Brake Light Troubles.....
Old Apr 5, 2004 | 11:20 AM
SATANAZ666's Avatar
Hi everyone,
I have this weird problem. I mean im confused as to what it can be. Heres the problem.
Whenever I press the brakes with the lights off the rear brake lights turn on as they normally should. BUT once I turn on the lights and I press the brake.....then Only one side lights up and the other side goes dark!...?????? I know weird huh.
Ive changed all the bulbs and everything is fine, I think anyway. Is there anything that I might have overlooked? or has this happened to anyone else before??? Any suggestions are appreciated. By the way Its a Trans am 94
thanks in advance
Old Apr 5, 2004 | 12:52 PM
magman's Avatar
check to make sure that the grounds are tight and clean. (Make sure the bulbs are the right ones also)
Old Apr 5, 2004 | 01:28 PM
SATANAZ666's Avatar
ALL THE BULBS ARE NEW AND ARE THE CORRECT ONES.....well are the tail lamp and the stop lamp lights the same???
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
