Check engine and both fans...
Old Apr 5, 2004 | 03:05 PM
ASIM's Avatar
Question Check engine and both fans...
Hey guys:
Can anyone tells me what this means. Just started the car for the first time in 4 months. Started fine, ran fine. After about 20 minutes though, I heard both fans kick in, even though the motor temp was only at a quarter, and the engine light came on.
Seemed to drive the same.
Any one make an sense of that.
Thanks for your help.
Asim
95 M6.
Old Apr 5, 2004 | 03:48 PM
95 WHITE TRANS's Avatar
Check your low coolant sensor.
NICK
Old Apr 5, 2004 | 04:04 PM
ASIM's Avatar
I have had that sensor go bad in the past as well, and the low coolant light comes on then.
Old Apr 5, 2004 | 04:08 PM
If the check engine light came on it threw a code get it scanned.
NICK
Old Apr 5, 2004 | 04:09 PM
The low coolant sensor is not even connected to the PCM. The most common problem with the SES light and both fans coming on is the AIR pump fuse.... but it would be odd for that one to come on after 20 minutes of running.
No substitute for a "scan".
Old Apr 5, 2004 | 04:12 PM
My friends 95 vette was running with both fans on constantly,the car was also missfiring it was a low coolant sensor.Check engine light was on.
NICK
Old Apr 5, 2004 | 04:42 PM
Corvettes and F-Bodies are different. The low coolant sensor is wired to the dash light in the F-Body, not the PCM.
David Dorris
Jan 17, 2015 08:10 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
