Weird stumbling...
Old Apr 6, 2004 | 12:03 PM
Drowned's Avatar
Weird stumbling...
After buying a new battery for my car, a new stumble came up at idle... very weird... the rpms drop from like 700 rpms to 500 rpms, just every once and a while, not all the time. If turn the wheel, it can make the car die cause of the low rpms. If i give it just a little bit of gas to bring the rpms up to 1200 rpms or so it completly clears up
Any ideas what could be causing this? Did I mess with some wire close to the battery that could be causing the problem?
Old Apr 6, 2004 | 12:37 PM
Bersaglieri's Avatar
Could be, but make sure you check plugs and wires. Make sure the plugs are tight and wires are all on good.
-Dustin-
Nayr
Mar 3, 2023 08:34 PM
BigED
Jun 26, 2015 10:58 PM
Zuvell
May 15, 2015 08:18 PM
reww86
Apr 27, 2015 05:17 PM
97z28k&N
Jan 9, 2015 04:58 AM
