Transmission Knocking!
Old Apr 6, 2004 | 04:00 AM
mike96lt1's Avatar
Exclamation Transmission Knocking!
I was fooling around in my car the other night(Raceing a Skyline GTR). At the line when I hit the gas I heard a loud knock coming from my trans. Since then evertime I get on the gas hard it sounds like the Trans wants to come throught the middle console. Could this just be the mount? or somthing worse ! Also when the tires brake loose the Trans starts to vibrate. I have a 96 Z-28 A4.
Old Apr 6, 2004 | 04:22 AM
Jay-Roll's Avatar
From what you describe it does sound like the mount. Get under there and pull off the crossmember to find out. It's only like 4 bolts. I had a horrible vibration problem under hard acceleration once also. Only happened during shifting though. Turns out it was my tranny, but when I swapped I found my mount was screwed as well.
Old Apr 6, 2004 | 05:55 AM
MentalCaseOne's Avatar
Tranny mount. Been there done that.
Old Apr 6, 2004 | 07:46 AM
93transam1234's Avatar
I second that. go get one today it will fix your problem befor it gets worse
Old Apr 6, 2004 | 07:48 AM
JoshGuitar's Avatar
get a poly tranny mount. It seems like once you break one, you start breaking them on a weekly basis until you replace it with something strong. A poly mount transfers more vibrations to the interior, but you get used to it, and it's much stronger than stock.
Old Apr 6, 2004 | 02:48 PM
Jay-Roll's Avatar
Second that. When I replaced mine I got an ES Poly mount. I think it was actually cheaper than from the dealer and it's held up perfectly. I never noticed a difference in interior vibration but I had a cutout also and that did enough on it's own.
Old Apr 7, 2004 | 01:08 AM
mike96lt1's Avatar
Thanks guys it was the mount and I have ordered a poly mount but only problem is I am in japan and it will be at least a week and a half till it gets here, guesss I will take it easy till then
Old Apr 20, 2004 | 10:40 PM
1FstFormulaV8's Avatar
Same thing happened to me. I went to a power slide and CLUNK! sounded like the tranny was gonna bust through the middle of the console. I believe I busted the mount.
I did indeed break the tranny mount. I jacked up tranny the the mount was broke right in half.
cmsmith
Sep 14, 2015 09:25 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
themex2002
Sep 2, 2015 03:47 PM
whitehooptie
Aug 10, 2015 07:02 AM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
