are these injectors compatible with lt1?
Old Apr 6, 2004 | 01:24 PM
will62085's Avatar
just wondering if the SVO 35# thunderbird supercoupe injectors are compatible with our cars?? they are low impedence injectors, with the same connector on them. i know i would need two sets (thunderbird = 4 cycl.) but just wondering if they would work??
Old Apr 6, 2004 | 01:40 PM
GreenDemon's Avatar
Are you sure they're low impedance???
From what I understand, replacement injectors should be high impedance unless you're running seriously away from stock (as in 800+ hp). The low impedance ones wouldn't be compatible without some good tuning work, and even then I don't know how well they would work on a street car. I haven't ever heard of anyone running the low imped. ones on the street.
Old Apr 6, 2004 | 01:53 PM
will62085's Avatar
from what ive read, the 30# and 35# injectors from the turbo 2.3 ford motor are low impedence injectors...i could be mistaken though...anybody know for sure?...i know people are running the 30# on their cars
Old Apr 6, 2004 | 01:55 PM
86T/AWS6's Avatar
and just FYI...the thunderbird supercoupes are 3.8L V-6's....the turbo coupes had a turbocharged 4 cylinder
Old Apr 6, 2004 | 02:01 PM
will62085's Avatar
ohh...well the ones im looking at are off the 4 cycl....so i guess its the turbo coupe...thanks
btw, ive got the bosch 28#, but the clips that hold the injectors to the fuel rail wont go on there, so im kinda worried about fuel leaks...anybody else run into this problem?
Old Apr 7, 2004 | 12:08 AM
will62085's Avatar
bump...anybody know?
Old Apr 7, 2004 | 04:16 PM
You can't run a low impedance injector on the stock PCM, unless you add an external "black box" to convert the systems. There is a box available, although I can't remember who makes it.
There are sometimes problems with the Bosch/SVO/FMS injectors and the clip locations. Are you sure it won't fit if you slide the injector very slightly out of the rail?
Old Apr 7, 2004 | 04:24 PM
RE AND CHERYL's Avatar
Don't worry about the clips, they are just used to hold the injectors in the fuel rail during assembly. The injectors are held in place by the fuel rail which is bolted to the manifold.
I was under the impression that ford used mostly high impedence injectors.
rwferguson43026
Feb 6, 2015 10:06 AM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
Jul 4, 2005 05:00 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
