Quietest gears??
Old Apr 5, 2004 | 01:13 PM
"White Knight"'s Avatar
Quietest gears??
I have heard many stories of bad gear wine on some gears. Just want some opinions on which gears to get. they will be 3.73's. Which ones do you have experiences with and which one do you believe it the best?
Old Apr 5, 2004 | 01:15 PM
My Red 93Z-28's Avatar
I think the amount of gear wine can be adjusted, it has something to do with how the pinion is set up against the ring.
Old Apr 5, 2004 | 01:23 PM
importeater's Avatar
From what I have read, Richmonds wine pretty good, GM/Motive are supposed to be just like stock. I am going to give Sierra Gear a try, from what I heard from the 4x4 guys they are just like the Motive gears, quiet, strong and the only thing I could find in 4.11's and not 4.10's.
Craig
Old Apr 5, 2004 | 01:24 PM
Is there any advantage to switching carriers? I have the 2.73's (2 carrier). I think switching the carriers is not too expensive.....like 20bucks.
Also wich one is GM gears? Is it Motive?
Old Apr 5, 2004 | 02:28 PM
IDOXLR8's Avatar
My vote is Strange Gears. Like stated earlier the proper installation is the key to avoid whine.
Old Apr 5, 2004 | 05:11 PM
LimitedEd1LE's Avatar
[i]Also wich one is GM gears? Is it Motive? [/B]
Yes Motive is a GM gear company. GM has their own gears too(OEM). Richmonds do have the most wine out of them all, but that is because they are a race cut gear.
Old Apr 5, 2004 | 05:40 PM
does strange make good gears? Then i wouldn't have to switch carriers seeing how they make them for both types
Old Apr 5, 2004 | 10:21 PM
96LT14u2Nv's Avatar
i have had Richmond, as do a few of my buddies and they are LOUD!!!!
i have GM Motive 3.73 gear and they are dead silent.
just my .02
Old Apr 6, 2004 | 06:17 AM
IDOXLR8's Avatar
Like I said above Strange does make good gears.
Old Apr 6, 2004 | 06:54 AM
Derrick Redd's Avatar
I have GM 3.42's in my Z28 and they are silent. The Richmond 3.55's in my LX have light to moderate whine.
Old Apr 6, 2004 | 09:24 AM
Fast Caddie's Avatar
Mine only whine between 60 and 65mph in 6th gear at light throttle. Its wierd cause they will only do it when you barely touch the gas while in gear. I'm always hammer-down so i rarely hear it
Old Apr 6, 2004 | 09:29 AM
badblackta's Avatar
um, I have a friend with richmond 4.11s in the stock 10 bolt and they have no wine whatsoever. My motives wine his richmonds do not, the guys who are saying that their richmonds wine must not have shimmed the gears right. They key to noise free operation is shimming the gears correctly.
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
