car only spins one wheel
Old Apr 5, 2004 | 08:14 AM
acslinger2525's Avatar
I have a 97 a4 z28. My problem is that i am only spinning one wheel. I dont want a locker as a daily driver. Any suggestions on what to buy to get this thing to spin both wheels? Thanks fellows
S .C. Smith
Old Apr 5, 2004 | 08:18 AM
Kataklysm's Avatar
Try changing the gear oil in the rear differential, sometimes the traction control just gets kinda crappy if the gear oil is old.
Old Apr 5, 2004 | 08:19 AM
Derrick Redd's Avatar
SLP has stock takeout posi units for $99 bux.
Old Apr 5, 2004 | 09:34 AM
slomarao's Avatar
how many miles do you have on the rearend(car)? after plently of abused miles the stockers crap out. There is the slp diff's but, if you can buy a 9/12 bolt rearend you mostly liked would be putting a pernment end to your problem.
Old Apr 5, 2004 | 09:35 AM
RE AND CHERYL's Avatar
Cool
I wouldn't waste time on the stock unit. If it has anything over 70k, it's worn out. The cheap way out would be a stock replacement take off unit from SLP. For $99 you can't beat it. There are better units out there, but you will spend $300-500.
Tractech makes a new gear type Posi called the Detroit Trutrack, it won't wear out and is suposed to be much better than a clutch or cone type. It's pricey, but I'm gonna get one. Check it out HERE, it's near the bottom of the page.
Old Apr 5, 2004 | 10:41 AM
MRBoss429x's Avatar
Does the SLP takeoff burn two tires around corners or only straignt line?
Old Apr 5, 2004 | 12:32 PM
thanks for all the help fellows, i will be calling SLP.
Noenav
Mar 1, 2019 07:38 AM
jj71787
Dec 30, 2014 02:15 PM
ro2207
Dec 4, 2014 06:18 PM
ChrisFrez
Nov 30, 2014 08:41 AM
USAirman93
Nov 24, 2014 03:37 PM
