What Injector Size?
Old Apr 5, 2004 | 05:16 PM
Supermanx500's Avatar
What Injector Size?
I went to the speed shop around where I live to start looking into what I need when i get some heads, and they told me that I need 38lb injectors and I was thinking that is a little big but what do I know. Here is my setup.
-383 stroker, XE 236/242, 1.6rr, Lt4 manifold, Valvetrain stuff, Midwest 3800TC, Every Bolton, Race Tranny, and more
The heads I am getting are....Either LE or Afr 220 w/Comp pkg.
(thinking about going with the GM847 cam when i put heads on) Not sure though
What Size Injectors should I be using?
thanks
Old Apr 5, 2004 | 09:21 PM
kmook's Avatar
Advanced Tech Moderator
I'd get those or bigger for that combo.
I had around 400rwhp (stock bottom end, heads/cam) and was about 80% DC with 36#'ers.
So you should be making more power than that for sure, so I'd definately get at least 38's.
You can do calcs here:
http://www.rceng.com/technical.htm
Old Apr 6, 2004 | 06:16 AM
IDOXLR8's Avatar
Re: What Injector Size?
thanks
Just remember when you decide to go with bigger injectors you will need a better fuel pump.
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
QuickSilver02
Apr 7, 2015 11:12 AM
drptop70ss
Mar 26, 2015 01:50 AM
