Reviving a motor...
Old Apr 5, 2004 | 05:05 PM
S8ER95Z's Avatar
Reviving a motor...
Ok, I ran my motor a short time with low oil pressure (5~10mins tops...long enough to get her home. Kept under 3,000rpm and was showing pressure on the first mark of the guage at 3K, no pressure at 2K) As soon as I got to town, I couldnt keep the RPMs high enough to hold pressure and it stalled out... wouldnt start again (seized?) basically I towed it home and its been sitting. I can spin the upper half of the motor (valves, cam, etc) the lower half will not turn over by hand. Can I use penetrating oil ? or is there a way to relubricate things enough to try and turn it over again? I believe I just had a bad oil pump/or the pickup tube came off. Im checking on that tomorrow morning. I just dont want to waste my time if I cant get the motor to crank over again. Ill just pull it and get it rebuilt instead of attempting to revive. Thanks!
Old Apr 5, 2004 | 05:08 PM
Compstall's Avatar
You're better off just taking it apart and figuring out what went wrong. Looks like your down that path anyway.
Old Apr 5, 2004 | 05:10 PM
S8ER95Z's Avatar
Yeah, I have the front of the engine off, just heads, intake and exhaust still connected. Im sure i could have the motor out in a few hours more time. I was just hoping for a miracle. LOL Ill probably just pull it this weekend. Thanks for the quick reply!
Old Apr 5, 2004 | 07:06 PM
race24x's Avatar
I hate to say it but you probably have done major damage to your crank and lower end. That low on oil pressure but still having some probably means you spun a bearing. The good news if there is any to be had is you can get a rotating assembly stroker kit and do the engine up modded.
Old Apr 5, 2004 | 07:17 PM
Dave88LX's Avatar
Sounds like time for a 383.
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
ohhiitznik
Apr 17, 2004 01:47 PM
NorySS
Sep 29, 2003 09:47 PM
guionM
55
May 2, 2003 09:34 AM
vodoo-chile
Nov 6, 2002 09:17 PM
