Running rich!!!
Old Apr 5, 2004 | 10:34 PM
BiGGinZ's Avatar
Angry Running rich!!!
I have had a running rich problem for a while now. I have put in new plugs, fuel injectors, and a cat on. I am not running an ses light all of the time. When I hit it a lot on one trip I notice that it will pop on and go off when I calm down for a little. Need help ASAP! I am running out of money and need to get it fixed. This car is my daily driver.
Old Apr 6, 2004 | 05:00 PM
BiGGinZ's Avatar
Need help!
Old Apr 6, 2004 | 05:21 PM
ChevyIron's Avatar
How old are your O2 sensors?Do you have any exhaust leaks?These will cause a rich condition.Check your fuel pressure at the schrader valve.
Old Apr 6, 2004 | 10:15 PM
BiGGinZ's Avatar
My O2 sensors have been on the car since it was off the showroom floor. It has near 120,000 miles on it now. But I don't have money to keep guessing and putting money into it and not fixing it. Any way I can find out if they are bad?
Old Apr 6, 2004 | 10:17 PM
Red96Lt1's Avatar
Are you sure it's not normal. Our cars are designed to run a little rich.
Old Apr 6, 2004 | 10:21 PM
BiGGinZ's Avatar
Like I can smell gas heavily. It makes my bumper black ( I have a white car ). My friend has the exact same car as I do and his doesn't do this.
Old Apr 6, 2004 | 10:32 PM
BiGGinZ's Avatar
Actually when I got the cat put on the exhaust guy said it had a slight exhaust manifold leak on the pass. side. Could this be doing it? What could I do to fix it.
Old Apr 6, 2004 | 10:37 PM
Myxtreme1's Avatar
Mine does the same thing but never a light. I'm pretty sure it's just 02's. Those are only good for around 100,000. I'm still waiting for my MAC headers to get here then I'll get them.
Old Apr 6, 2004 | 10:38 PM
97 RedSS's Avatar
Sounds like your missfiring on 1 or 2 cylinders and its spitting out the unburn fuel into the exhaust..
Cody
Old Apr 6, 2004 | 10:39 PM
BiGGinZ's Avatar
Cody
What do I do to fix that?
Old Apr 6, 2004 | 10:42 PM
Spinner's Avatar
Get an infrared temp gun, and hit each header/manifold primary with it. The ones that are a lot colder then the rest are misfiring. Check THOSE wires/plugs carefully, as that's where your problem lies.
Old Apr 6, 2004 | 10:44 PM
BiGGinZ's Avatar
But I just got new plugs put in. How hard would it be to put new wires on with the headers still on? I have heard horror stories about that.
Old Apr 6, 2004 | 10:46 PM
97 RedSS's Avatar
Many things can cause a cylinder not to fire properly...opti/spark plug gap/plug wire/anything in the ignition...
I would just pull your plugs after letting it run a while and see what they look like.
Cody
Old Apr 6, 2004 | 10:50 PM
BiGGinZ's Avatar
What can I do to find out without spending a lot of money on stuff I don't need. I have already put in around $700 or so trying to fix it and nothing yet. I have very little money left because I don't work (That is what I need it to be running right for).
Old Apr 6, 2004 | 11:48 PM
BiGGinZ's Avatar
I am thinking of doing the wires. Like I have said I had the plugs done about 250 miles ago so I don't believe it is the plugs. Or should I do the O2 sensors. To tell the truth I don't even know where they are. Or should I get the ex. man. leak fixed. What should I do to fix it? Need help and tell me your est. cost on everything. Because like I have said I have near nothing in money.
