code #P0443? Help!
Old Apr 5, 2004 | 03:52 PM
RedWS6TA's Avatar
code #P0443? Help!
i am throughing the code po443. i just did heads and cam what did i forget. help!
Old Apr 5, 2004 | 04:06 PM
P0443 = Evaporative Emissions (EVAP) purge solenoid control circuit
You should really bookmark Shoebox's code list:
http://shbox.com/1/Dtcs.htm
Old Apr 5, 2004 | 04:08 PM
RedWS6TA's Avatar
it is an obd2 if that matters but what the hell does that really mean. i looked it up in my repair manual but didnt know for sure what that means
Old Apr 5, 2004 | 04:45 PM
We can tell its OBD-II, because of the Pxxxx format for the code.
The EEC purge solenoid is located on the bracket in the middle of the passenger side of the intake manifold. The solenoid is burned out, or the connector is not connected properly.
You can also find info about virtually any component on Shoebox's website.
http://shbox.com/1/1996_evap.jpg
Old Apr 5, 2004 | 04:52 PM
RedWS6TA's Avatar
is this a must that has to be hooked up. i have taken all of the egr stuff off. and does that effect the way my car runs?
Old Apr 5, 2004 | 05:07 PM
SSnakeEater's Avatar
your evaporitive system is baisically just a system to control the evaporating gas fumes from your gas tank back into your intake manifold. if it doesnt work you will just produce more HC emmisions.
Old Apr 5, 2004 | 11:46 PM
But the EEC evaporative emissions system is not part of the "egr stuff".... it is an independant system. From my experience, when it is not working, you generally get a lot of gasoline smell from the rear of the car. Collecting the fumes, and then burning them in the engine would actully help fuel mileage.
Just curious - Why would you remove parts when you don't even know their function?
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
