will this be the cause of my miss? pic inside
Old Apr 6, 2004 | 07:26 PM
cridom's Avatar
im doing an opti install because i thought it was that until i saw my coil.
do you think i should forgett about the opti and just change the coil?
how do you get those metalic boots out of the wire boot ?
thanks
http://www.cardomain.com/memberpage/339098/2
its the last pic on page 2 in my webpage
Old Apr 6, 2004 | 08:00 PM
cridom's Avatar
ttt
Old Apr 6, 2004 | 09:07 PM
Spinner's Avatar
Greetings from CarDomain. Our web sites are temporarily unavailable due to scheduled maintenance. We are working to return our sites to service as quickly as possible and apologize for any inconvenience caused by this issue.
Old Apr 6, 2004 | 09:33 PM
cridom's Avatar
well the whole point is that its got a white thing all over like corrosion. and a bit of rust. can that cause my miss at high rpms?
Old Apr 6, 2004 | 09:53 PM
Spinner's Avatar
Could very well be. As cheap as coils are, might as well replace it AND the coil wire. Be sure to use dielectric grease
Old Apr 7, 2004 | 10:05 PM
cridom's Avatar
ttt
Old Apr 7, 2004 | 10:53 PM
Any corrosion found on spark plug wire ends or any terminals should be considered a suspect for poor performance. Repair or replace the offending parts.
Old Apr 7, 2004 | 11:10 PM
IrocSS85's Avatar
yeah, thats it. if a cyl is misfiring, thats the first thing I look for is corrosion on the coil. its very common and will def. cause poor spark and misfires. repl. coil and wire, and use dielectric grease as suggested on here. def. hold off on the opti till you try this to see if thats the only prob..
chris
cmsmith
Mar 16, 2015 02:34 PM
mattstrike
Mar 11, 2015 07:33 PM
rjc1629
Jan 27, 2015 10:46 AM
Deadbolt24
Jan 19, 2015 01:29 PM
omarECD
Aug 19, 2002 07:28 AM
