How high can I stall my stock '95 Z28 with 3.23 gears?
Old Apr 4, 2004 | 11:20 PM
warwickbass's Avatar
Yeah, to launch off the line or should I just floor it? Which would be quicker? Thanks.
Old Apr 4, 2004 | 11:30 PM
iNF3RNo's Avatar
Stomping from a stop, my stock '93 w/ 3.23 rear breaks the new Michellin Pilot's loose for a good 2-3 seconds. Gets sideways a little too.
I'd imagine it depends mostly on your tires. What are they?
Old Apr 4, 2004 | 11:32 PM
Sumitomo (245/45ZR17)
Yeah, it fishtails somewhat when I step on the accelerator pretty hard.
Old Apr 4, 2004 | 11:41 PM
Bersaglieri's Avatar
Are 3.23's ok with a stall? I thought you had to upgrade to 3.73 or it would bog. Or can you use a lower 2400 stall with it for streetability?
-Dustin-
Old Apr 5, 2004 | 12:00 AM
iNF3RNo's Avatar
I think he means torquing the brakes, power-braking, whatever. Drag radials would probably be needed to launch better.
The idea is to give it the most throttle you can without breaking the tires loose. Otherwise that power isn't getting to the ground...
But with tires spinning, the engine isn't under as much load, so revs climb faster and you're getting deeper into the powerband, for when you finally hook. Same end result as a TC, right? I still assume it's better to just keep traction though.
Cam's maro
Dec 28, 2014 09:30 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
teedoff59
Aug 8, 2002 01:36 AM
