lt4 hotcam dyno
Old Apr 5, 2004 | 03:49 PM
95firechicken's Avatar
lt4 hotcam dyno
i got a chance to dyno my car on am mustang dyno. base run was 312hp,325tq. third pull was the best as it pulled 325hp/340tq. does this sound right for the hotcam and prted heads? what kind of numbers would i have put down on a dynojet?
what kind of increases would i see going with the 233/239 or the 847? how is the torque curve on thos cams look?
Old Apr 5, 2004 | 04:29 PM
Reptile5.7L's Avatar
in just the lt4 cam kit ur dyno is alright, but ported heads too, then ur numbers are little bit low, not that low but u can spect more from aported heads and lt4 cam, did u tune ur pcm??????
Old Apr 5, 2004 | 05:03 PM
SS MPSTR's Avatar
Your numbers are right on. A Mustang dyno tends to record numbers at the lower range as compared to a Dynojet.
If your car is running good, go race the car and see how it performs.
Old Apr 5, 2004 | 06:18 PM
i got a chance to do a lil tuning with it, didnt get a chance to finish it. i was told those numbers on a dyno jet would come out to about 350hp/365tq. does that sound about right. what kind of gains would i see with the 233/239 cam.
Old Apr 6, 2004 | 01:36 PM
LT4Firehawk's Avatar
I'm not sure I'd say they'd be that high. Most LT4 cars with the hotcam only put down 330-340RWHP on a dynojet, although I have seen some with full boltons go as high as 360. A lot of it depends on how good of a port job your heads had. The easiest way to really get a good comparison is just going to be finding a dynojet in your area and dynoing on it.
Old Apr 6, 2004 | 03:30 PM
nearest dynojet is about 45 min, and is always busy. i was able to get on the mustang dyno and get 3 pulls for $40.
football4life
Oct 4, 2015 07:48 AM
fift5
11
Oct 1, 2015 10:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
