1LE Lower A-arms
Old Apr 5, 2004 | 12:18 AM
JD30thZ28's Avatar
1LE Lower A-arms
What is different about the 1LE lower a-arms??? Thanks
Old Apr 5, 2004 | 12:29 AM
carlos64030's Avatar
There's no such thing as a 1LE a-arm. All f-bodies utilize the same suspension components except for the shocks, springs and bushings. Where did you get the idea that they were different?
Old Apr 5, 2004 | 12:39 AM
JD30thZ28's Avatar
They talk about it in this thread
http://web.camaross.com/forums/showt...ht=stock+aarms
Old Apr 5, 2004 | 09:52 AM
LT4Firehawk's Avatar
I just had to get new lower front control arms, and apparently their is only one replacement part for all 4th gen f-bodies, and it's supposed to allow greater negative camber. This part supercedes ALL other 4th gen lower front control arms.
Old Apr 5, 2004 | 10:58 AM
Hey Evan...how does your new a-arms compare to your standard issue parts, do they look the same or what, do they weigh less or anything?
Old Apr 5, 2004 | 11:04 AM
Don't know yet, the shop is still waiting for them to come in. Apparently nobody around here had any in stock. It's been about a week now, so I'm guessing they must be coming directly from a GM wharehouse somewhere.
Old Apr 5, 2004 | 11:33 AM
fastcamz28's Avatar
When I ordered 1LE lower a-arms from Del, he seemed to know what I wanted and didn't correct me (if I was using the wroong terminology). From various postings in the Autocross/Road Racing Forum, it would seem there are, in fact, 1LE lower a-arms. Maybe Jason Cromer could add something here...
Old Apr 5, 2004 | 01:39 PM
Soooo...no one knows what differentiates a 1LE a-arm from standard issue? There has to be some kind of noticeable difference besides the additional negative caster that was stated in that previous post.
Old Apr 5, 2004 | 02:01 PM
Well here's the scoop...I just got off of the phone with Jason Cromer and there is an a-arm under the 1LE option code. But, he believes that the a-arm is the same as standard issue, only the bushings are different.
Old Apr 5, 2004 | 02:03 PM
fastcamz28's Avatar
Thanks for clearing that up!!
Old Apr 5, 2004 | 03:08 PM
JD30thZ28's Avatar
Arrow
Thanks for checking into that
Old Apr 5, 2004 | 03:51 PM
No problem guys.
Old Apr 5, 2004 | 05:13 PM
961le's Avatar
the bushings are different. and not replaceable. if the bushings wear out you have to buy new a arms. $800 for the front , i checked on this about 6 months ago.
Old Apr 5, 2004 | 07:20 PM
The bushings are replaceable. I replaced my bushings about 4 years ago with poly bushings. You have to burn the old ones out.
Old Apr 5, 2004 | 07:38 PM
Bud M's Avatar
$800? Are they MAGIC A arms?
