Header primary touching brake line
Old Apr 6, 2004 | 06:20 PM
ROWYCO's Avatar
Well the #1 primary of my Jet Hot header is touching the shield that guards the brake lines. Will the lines be fine or do I have to move them, and if i do, how can I go about it without screwing things up?
Old Apr 6, 2004 | 06:50 PM
Cmr0z28's Avatar
My friend was driving and burnt thru the hard brake lines....I would move them ASAP. He has the same headers you have by the way.
Old Apr 6, 2004 | 07:02 PM
Spinner's Avatar
Mine's also touching a line. What's a good way to bend these without kinking/hurting them? Anyone
Old Apr 6, 2004 | 07:19 PM
rob96TA's Avatar
I poped mine off of the clips on the strut tower next to the primary, then took that heat shield and flated it out and shaped it so it came about 2 inches away. When i bring my car out, I"ll be making a new shield out of Thicker steel, and wraping it and the brake lines in thermal barrier tape. I recommend doing this to any ABS wiring as well.
Old Apr 6, 2004 | 07:32 PM
Spinner's Avatar
So you just bent yours by hand slowly? I was thinking about using a brass pipe bender
Old Apr 6, 2004 | 07:40 PM
FormulaLT-1's Avatar
errrrrrrr, I just bent my heat sheild back a bit...
Cmr0z28- you have any pics, I'd have to see how bad his was :\
Old Apr 6, 2004 | 08:02 PM
Cmr0z28's Avatar
Sorry, I don't have any pics, but the result was him stuck on the way to work, and several hundred dollars in repairs
Old Apr 6, 2004 | 08:14 PM
did he not have a heat sheild on it??
I'm still trying to see how this happened to him, got me kinda nervous.
Old Apr 6, 2004 | 09:38 PM
rob96TA's Avatar
no, i just reshaped the heat shield using a hammer and dolly. it took 5 test fits till i was happy with it.
Brake_L8
Jan 20, 2015 09:44 AM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
