what else can i do???
Old Mar 16, 2006 | 01:05 AM
scottslt1z28's Avatar
Is there anything im missing????
besides gears and a stall (which are coming in the next couple months)
what other "bolt-ons" or free mods are there that i can do to eek more power out or to reduce weight???
MODS:
-Listed in SIG
-free mods:
--tb bypass
--valve cover breather
--!egr, !air
electric water pump & what else??
Old Mar 16, 2006 | 01:30 AM
urbaNHunter44's Avatar
Re: what else can i do???
Not really unless you want to start taking weight out. If you do, check out some of the weight loss threads on LS1tech. I think theres one that lists each piece individually and what it weighs.
Also remember that with tires, the stall and gears are going to cut at LEAST .5 off your 1/4 if you can drive. You should already be nipping at 12s with a tire. You can also do rocker arms if you want. You can do smaller things like pulleys or EWP. Invest in a 12 bolt.
After that, get some spray or go heads/cam.
Old Mar 16, 2006 | 01:31 AM
MeanGreen97Z's Avatar
electric water pump.... throttle body....
Old Mar 16, 2006 | 01:56 AM
im picking up my MT et streets tomorrow.................im hoping that will get me to the 12's
Old Mar 16, 2006 | 05:09 AM
2000GTP's Avatar
Rockers.
Old Mar 16, 2006 | 06:42 AM
Suggestion.... get an electric water pump, 1.7 RRs, and a throttle body with a tune. I bet you pick up a bit from that!
